TwinTurbo.NET: Nissan 300ZX forum - Do an Alignment.. Also put some wider rear tires..
Carlos Ramirez
on February 23, 2001 at 5:40 AM
Sounds like a camber problem...
posted by John Y(Houston)
on February 23, 2001 at 01:04 AM
The stock rear tires are 245s you down graded them by putting 225s in the rear.. Maybe 225s in the front and 245 or a 255 in the rear it will fit on that rim.
anyone have troubles with 18" wheels
ryans300
00:56:04 02/23/01
it is only on the rear wheels (n/m)
ryans300
01:00:32 02/23/01
John Y(Houston)
01:04:16 02/23/01
Do an Alignment.. Also put some wider rear tires.. -
Carlos Ramirez
05:40:07 02/23/01
225 rears?? What is your offset? Should be plenty of room. (n/m)
Dpilati
01:04:47 02/23/01
Maybe the wheel offset is wrong (n/m)
F8IZHIS
01:10:16 02/23/01
Confused. Due 2 tire wear or rubbing? If former >>>
teahead
13:24:29 02/23/01
